M800 for 2 rotor setup is only able.to use 4 inj drivers
Fri Mar 29, 2013 3:35 am
by Fast20b
Is there any way to use all 8 inj drivers on the 2 rotor setup. Once you choose 2 rotor setup it only let's you use 4 inj drivers only. Are there any options for using all 8?. Can Motec do anything for this? We bought the m 800 thinking that we would have access to all drivers.
Re: M800 for 2 rotor setup is only able.to use 4 inj drivers
Fri Mar 29, 2013 12:30 pm
by 20B
Yes pretty sure you can run 4 pairs of 2 would solve your problem. , don't think you can drive all 8 sequentially.
Fri Mar 29, 2013 2:20 pm
by Fast20b
Low impedance injectors need one driver for each one.
