Boost switching on M800
Hi Guys,
i want to have a higer boost setting in 5th gear in my car, im running an air shifted lenco, i want to put an air switch in the line that controls 5th gear,
I want the switch to Ground or feed 12v to the m800 so it knows im in 5th, this will than change the boost map to get higher boost,
doing the wiring and installation is easy and straight forward,
Question is, When online with the motec how and where do i go to configure the input?
what will i be telling the motec to do and how do i do that.
I know these are lay mans terms but you get what i mean
