m800
Fri Mar 08, 2013 10:41 am
by yhubaldiaz
hi can anyone help with the software I have a launch control activated in 3.5 but when I turn it on a 2.3 software does not work something is missing
Re: m800
Wed May 15, 2013 2:14 pm
by YuriK
Do you mean the Launch control doesn't work on ECU version 3.5 with the configuration file converted from 2.3 to 3.5? If that is the case you need to check all your settings because there were major changes between v2.3 and v3.5 so some functions do not work the same.
Regards!
