Predefined Wideband Values
hello
can anyone tell me what are the values wich are predefined in the motec ecus ?
in Sensor input setup i can chose :
#40 Lambda: Bosch Wide Band Meter
#41 Lambda: NTK Wide Bank Meter
wich voltages are there predifined in Motec Software ?
are following Values Correct ?
Volt = 0,000 1,750
Lambda = 0,000 1,750
NTK Wide Band Meter
Volt = 0,000 5,000
Lambda = 0,500 1,500
is this correct ????
Volt = 0,000 1,750
NTK Wide Band Meter
Volt = 0,000 5,000
