Predefined Wideband Values
Postby ramiretz on Mon Mar 04, 2013 12:10 pm
hello
can anyone tell me what are the values wich are predefined in the motec ecus ?
in Sensor input setup i can chose :
#40 Lambda: Bosch Wide Band Meter
#41 Lambda: NTK Wide Bank Meter
wich voltages are there predifined in Motec Software ?
are following Values Correct ?
Volt = 0,000 1,750
Lambda = 0,000 1,750
NTK Wide Band Meter
Volt = 0,000 5,000
Lambda = 0,500 1,500
is this correct ????
ramiretz
Re: Predefined Wideband Values
Postby YuriK on Fri May 10, 2013 5:27 pm
These are definitely the calibrations you can see in the ECU manager, so these are the values the ECU uses.
Regards!
YuriK
Users browsing this forum: No registered users and 43 guests
