Ref/sync mode "8"
Hi friends,
This is the first engine that i don´t use sync sensor ( i always run sequential, only in this project i had to go for semi-sequential route) and the ref/sync mode that i found to this setup is the number 8 (two missing once a cycle).
The trigger wheel is default BMW type: 60-2. There is no sync sensor, just ref sensor.
My current setup:
Engine: 12 cyl engine
Cylinders setup: 612 (injectors wired in pairs)
Ignition setup: 6 ignition coils (wasted spark, so using 6 ign outputs to fire the 12 cylinders)
Ref/sync mode: 8
Is ref/sync mode correct for this setup? My ref sensor is on crankshaft not in camshaft. If there is other ref/sync mode that can use in this setup i will really appreciate if you can share with me.
Thank you in advance!
My current setup:
Ref/sync mode: 8
