DBW 2009 WRX won't run below 2000 RPM
Postby golf_bht on Sun Feb 03, 2013 4:15 am
I need some help. My car won't run below 2000 RPM. the car is all stock except a new turbo. It idle nicely on reflashed OEM ecu.
It look like the throttle have a set of spring which give it a defalt openning at 10% should the system fail. Now i could only move the throttle anywhere from 10-100% but nothing below the mechanical preset of 10% for idle control.
The throttle won't move below 10% for idle control. the rpm gone down when I manually push the throttle body to below 10% though. I can't set the system to give me less than 10% throttle with DBW controlled by motec.
What could be the problem?
golf_bht
Re: DBW 2009 WRX won't run below 2000 RPM
Postby golf_bht on Sun Feb 03, 2013 5:09 pm
here is the hex file from my ecu. Does anyone sopt Whatt I have done wrong?
2259 RPMlimit2.e35
(72 KiB) Downloaded 1081 times
golf_bht
Postby MattW on Mon Feb 04, 2013 9:44 am
You may need to calibrate your Throttle position sensor.
This is explained in detail here.
MattW
Postby golf_bht on Tue Feb 05, 2013 4:01 am
Thankyou very much. My car is up and running as it should now.
golf_bht
Users browsing this forum: Majestic-12 [Bot] and 5 guests
