Current and ratio for 16 injectors?
Hi all,
We have a four cylinder dragbike with 4 injectors per cylinder, arranged in two banks of 8 injectors. The injectors are wired in parallel in pairs. They are high impedance Siemens GAS004 injectors.
We are getting injector errors flagging up on the datalog at 200kpa manifold pressure, the secondaries should start working at 150kpa, which they appear to do as the bike goes rich, then goes weak again at 200kpa as the error occurs, it looks like the secondaries aren't working.
We have the current for both primaries and secondaries set to 0, and the ratio set to 4. Is this correct? It's an M800 unit.
