GSX-R600 w. M400
Hi guys,
I'm trying to build a FSAE car with a GSXR-600 engine.
First I had to change the camshaft pin so the crank & cam signals won't be clashing.
I've been configuring mag voltages and so on but I still have an error which I don't understand.
I let you the ref/sync capture and the errors:
I let you the link to the second image since I'm not able to see it properly in my navigator: http://i.imgur.com/IIUdz.jpg
When I changed the cam pin I think it didn't fit very well and the cam signal was too big comparing to the crank signal. I managed to fit a little more and now both signals have the same peak voltage. By default the cam signal was a little bit bigger but I think both signals are clean enough to read.
I'm using ref/sync mode 7, teeth number 24.
Thanks guys
Thanks guys
