GSX-R600 w. M400
GSX-R600 w. M400
Postby sabo on Sat Jan 19, 2013 1:02 am
Hi guys,
I'm trying to build a FSAE car with a GSXR-600 engine.
First I had to change the camshaft pin so the crank & cam signals won't be clashing.
I've been configuring mag voltages and so on but I still have an error which I don't understand.
I let you the ref/sync capture and the errors:
I let you the link to the second image since I'm not able to see it properly in my navigator: http://i.imgur.com/IIUdz.jpg
When I changed the cam pin I think it didn't fit very well and the cam signal was too big comparing to the crank signal. I managed to fit a little more and now both signals have the same peak voltage. By default the cam signal was a little bit bigger but I think both signals are clean enough to read.
I'm using ref/sync mode 7, teeth number 24.
Thanks guys ;)
sabo
Re: GSX-R600 w. M400
Postby MattW on Tue Jan 22, 2013 9:04 am
Hi Sabo,
Can you attach your configuration file for us to see?
I can't see what is wrong without first seeing what you have set.
MattW
Postby sabo on Sat Feb 23, 2013 5:17 am
Hi again,
We managed to make that work.
Now we're getting a Over RPM error and we don't know what does it mean since we don't have any RPM limit set.
Do you need the file in this case?
Regards,
Sabo
sabo
