Ok here is the plan
Setup the inlet with some 250 hp jets (fogger NOS flares x4). The fuel will be supplied by the injectors (8x) that are currently running at 50% duty cycle so there is plenty of fuel for this hit.
The problem is 250 hp is a sizeable hit on the drivetrain (Aspen 6 speed and Torsen diff) so I want to pulse the relay that drives the n2o noid so as the 250 shot comes on gradually rather than all at once.
The N2O setup at the moment (100 shot) uses and AUX into the ARM switch and then a DIG from the noid. It also has an AUX to an AT so we have not only RPM vs TP but also Ground Speed vs TP (I only shoot in 4th gear or higher and only above 5k RPM).
My tuner is unfamiliar with the new Nitrous setup in the software and I'd like to help out as much as possible while still looking after my machinery.
My question is how do I set up the MXXX to provide this gradual hit.
Cheers,
Bazz
