Idle Control Not Functioning( AIM Error 0 )
I have an M400 with DBW and have not been able to get the idle control working. I have setup the Idle control and the idle aim RPM table, see below. After looking around in ECU manager I have found that the AIM RPM and Aim Error are 0 while the motor is idling so that is why the idle control is not working. I have checked the TPd and TP positions and they are well below 10%, ground speed is 0 and idle speed is 1000 - 2400 RPM. Idle Aim RPM Comp is 0, Idle Min output table is set to -100, Idle Max output table set to 200, Idle min Integration limit table set to -10, idle max integration limit table set to 30, Idle Initial Position -200, Idle normal position 0, Idle fuel and ignition comp 0.
Is there some other setting I'm missing to get this to work ?
Any input is appreciated.
Mike D.
Mike D.
