Sync Rel Pos
Tue Oct 23, 2012 5:29 am
by stevesingo
Am I correct ins stating the Sync Rel Pos should be as close to 50% as possible?
What is the acceptable limits for Sync Rel Pos?
Many Thanks
Steve
Re: Sync Rel Pos
Wed Oct 24, 2012 7:23 pm
by MileyCyrus
Ideally, yes, the sync relative position should be closer to 50%, as this gives you the largest amount of leeway in the mechanical play inside the engine. However it isn't overly critical with how close, with anywhere inbetween 25% and 75% fine depending on the amount of play in the engine, viewable by logging the value in the ECU.
As long as it doesn't get anywhere close to 0% or 100% or is possible to fluctuate over these values, ie. from 100% to 0% on the next crankshaft tooth, it should work fine, as all the fueling and ignition timing based on the index tooth.
Cheers,
