Hi/Lo fuel control on L6 with 10/12 cylinder upgrade
Postby Blu302 on Thu Sep 06, 2012 6:29 pm
Can Hi/Lo injection be used on a straight 6 with the 10/12 cyl sequential upgrade? I'm looking at running 2 seperate fuel rails for seperate fuels on a BMW M52. Using an M800 ECU.
Blu302
Blu302
Re: Hi/Lo fuel control on L6 with 10/12 cylinder upgrade
Postby MarkMc on Wed Sep 19, 2012 3:27 pm
You do not need the 10/12 cylinder upgrade for this. If it is set up as a 6 cylinder and you use hi/lo injection it will use 4 of the ignition outputs (leaving only 2 ignition outputs for actual ignition). The primary set of injecotrs uses the ignition outputs so these injectors need to be high resistance injectors.
Postby Blu302 on Wed Sep 19, 2012 8:27 pm
Looks like I only need a few IEX modules then.
Blu302
Blu302
Users browsing this forum: No registered users and 20 guests
