Toyota 1UR engine ref/sync VVT setup.
Postby Alex B on Tue Aug 21, 2012 10:29 pm
Does anyone know ref/sync mode and cam control parameters for this engine?
Its 36-2 mag on the crank, however I don't know tooth count / pattern on cams.
Its V8 with DBW and IN/EX variable cam control used in Lexus LS/GS 460 and some
Toyota SUVs starting from 2006 onwards.
Start file or any info is appreciated.
Regards
Alex
Alex B
Re: Toyota 1UR engine ref/sync VVT setup.
Postby Martin on Mon Aug 27, 2012 6:25 am
Ive got some info on the 1UR
Do you know that its DI as well as port? This is the case for the 1 UR FSE. There is a 1 UR FE version as well as far as i know but have never seen it. The next obsticle is the inlet cam control which is electric and not electro-hydraulic as most othet cam control systems. Its Duty cycle/Freq controlled.
What info do you have on this engine?
To run this an M800 with ADL3 could work in theory, but the M1 is the tool for the job.
