S2000 Ref/Sync
S2000 Ref/Sync
Postby Ben-S on Wed Oct 22, 2008 11:35 pm
I have created a plug and play wiring harness and basemap for the MX00 series ecu's that I would like to sell. Currently the only thing holding me back from putting it on the market is the trigger pattern. On my race car i have simply changed the cam trigger to a single tooth rather than the original 3 tooth wheel. This is not as simple of an option for the general public as most of them would not want to pull their cams to grind off the teeth or lose the ability to use the factory ecu when needed.
The ref is 12 teeth/rev and the sync is 4 -1 (4 evenly spaced teeth 1 missing tooth). The car has 2 cam sensors but only one is used and there is no variable valve timing (other than standard VTEC).
Is there any possibility of this OEM mode being release in the near future?
Thanks,
Ben
Ben-S
Re: S2000 Ref/Sync
Postby RossB on Thu Oct 23, 2008 10:17 am
We have had quite a few requests for this. I will put in a request for a ref/sync mode for this engine to be included in futyre software versions.
Re: S2000 Ref/Sync
Postby Ben-S on Thu Oct 23, 2008 11:05 am
Thanks Ross
Ben-S
Re: S2000 Ref/Sync
Postby RossB on Fri Oct 24, 2008 8:51 am
I have sent you a PM Ben.
Re: S2000 Ref/Sync
Postby jeremyj2e on Sun Nov 02, 2008 8:59 am
I came to this forum to find out if there was a MoTeC solution for the S2000, so I was very happy to discover this thread. I just wanted to say that I am a potential customer of Ben's and am waiting for the software change before ordering the system.
Jeremy
jeremyj2e
Re: S2000 Ref/Sync
Postby Ben-S on Wed Nov 12, 2008 2:40 pm
Up and running on the PnP harness and stock cam sensor.
Thanks Ross, and everyone else over at MoTeC Australia
Ben-S
Re: S2000 Ref/Sync
Postby bing on Thu Nov 13, 2008 1:15 am
How did you get the oem trigger to work?.. Did u have received the new beta software? or via new base map?..
i want to know too.. i am in the middle of wiring/setting up one..
bing
Re: S2000 Ref/Sync
Postby RossB on Thu Nov 13, 2008 8:41 am
This mode will be included in the next release of ECU Manager.
