Aux 8 breaker switch
I've got my fuel pump connected to AUX 8 and i've made a kill switch by breaking the AUX 8 wire and wiring in a button, it seemed to me like a reasonable solution, however, after some time, my fuel pump would not prime even when the switch is set to ON. I replaced the switch and everything started working again, but after a week, the same thing is happening: if i leave the switch in the ON position, the fuel pump wont prime and i have to turn it off and the on again to make it work. What gives ? The switch is rated at 15 amperes.
