Hello.
In order to make the tacho output work for my Toyota original tachometer ( 20 volts ), I need to know how much is the voltage Aux4 output in an M400: 5v or 12v?
Thanks.
Martin wrote:Wire Aux4 to your Tacho and add a 4.7Kohm, 1/4 watt resistor between 12v and the tacho signal.
Martin wrote:Yes.
You wire the resistor between 12v and the tacho signal.
the Mx00 ECU`s only do highside on the following outputs:
Aux1
Aux2
Aux5
Aux6
Aux7
Aux8
Regards
page 81, m400 m600 m800 manual
