Can M800 use CAN input data for control value?
Hello.
I use M800 for motor cycle.
Handle switch of My motor bike has Up down switch.
The switch is connected to M800 in order to output 2.5V in neutral, 5V in Up and 0V in down.
I wonder if its switch can be used for level select of traction control
and to control level of correction coefficient about IG or FI.
There are 2D logger system in my CAN network.
so I came up with the following idea:
No 1. When Up(Down) bottan is pushed Analog-data outputed by Can from terminal SV(0V) is read by 2D logger.
No 2. If Swctch is Up(5V) and 5V is sent to 2D by CAN, 2D increments arbitrary counter.
If Switch is DN (0V) and 0V is sent to 2D by CAN, 2D decrements arbitrary counter.
No 3. The arbitrary date worked out by No.2 is sent MoTec by Can-ID.
and Motec use the deta for level of date of TC
Could you tell me if M800 can use CAN input data from outside for controlling value ?
