DBW throttle calibration
Hello
I've a question about how to calibrate my DBW throttle setup - Sensor Setup - Throttle Position Hi/Low
I guess the driver - pedal has to be calibrated in the min. and max. position - but what about the throttle?
I've the following positions.
1- fully closed
2- a few degrees open (where it stays with no power on)
3- 90° - maximum flow
4- ~100° - end stop (closing again to the other side)
which one is the correct open position? 90° or end stop? - I currently use the end stop position and only use max ~ 90% in the position translation
do I need position 2 or shall I adjust it to fully closed?
the engine is from a civic type r - k20z4
thanks!
which one is the correct open position? 90° oder end stop? - I currently use the end stop position and only use max ~ 90% in the position translation
thanks!
1- fully closed
thanks!
thanks!
