Hooking up gear position to M400
I need to hook up the gear position to the ECU and would like to do this via an AT input and the voltage based gear detection.
I have 3 gears and each has its own soleniod so I have a seperate 12v volt feed for each gear. If I can regulate the voltage to the ECU from each solenoid it will recognise which gear is engaged right?
So can anyone tell me what I need (inline diode? etc. etc) to limit the voltage in each gear to set this up?
Thanks for your help.
