Printer Port CAN Cable
Postby shrek69 on Thu Mar 22, 2012 12:12 pm
Hello
Are there any solutions to use the "Motec Printer Port CAN Cable" on a laptob without printerport?
PCMCIA or USB convertors???
shrek69
Re: Printer Port CAN Cable
Postby MarkMc on Thu Mar 22, 2012 3:55 pm
We have had a UTC (USB to CAN) adaptor available for many years now. An old CAN cable generally has not been used fro a long time.
What ECU do you have and what version of software?
Postby shrek69 on Thu Mar 22, 2012 7:09 pm
Hello Mark
I used the Adapter in the year 2000
Now i need it for a new M84, but i still have some "old" M800 to do.
I know that there is the new USB to can.
Maybe there is a spezial deal from Motec for user of the old adapter.
Send old back and buy new for spezial conditiopns?
Regards Bruce
shrek69
Postby Polux RSV on Fri Mar 23, 2012 3:06 am
I found this device. It is not a classic USB to parallel for printer only. It emulates a true LPT port. It appears as a real LPT port on PC, where any software could use it. I never tried it, and don't know if Ecu Manager will be ok with it.
As this question comes back from time to time, it will be nice if someone at Motec could try it, or at least check the site and infos with the Ecu manager LPT port driver.
Angelo
Polux RSV
Postby MarkMc on Tue Mar 27, 2012 4:38 pm
Old M800s should still be upgraded to the new software and using the UTC.
Sorry but no, there are no special conditions for swapping the old CAN cable. :)
