M800 with CO2 Boost Control
I woul looked to setup the boost control on my single turbo v8 using c02 to the top of the Wastegate, this will allow me to use a really light spring (5psi) for my low boost and be able to wind the boost up to 20psi without any street OS the highinsh back pressure blowing the gate open etc, I currently run a 9psi spring which isn't low enough for me on the start line at the drag strip and use around 70% duty cycle on the solenoid to get to the aim boost of 17psi.
How would I need to plumb a 3 or 4 port solenoid with my external Wastegate to use co2 on top of the gate, how would the m800 need to be setup?
