Paddle gear shift
I currently have a m400 ecu on a suzuki gsx-r k3 engine on a formula student car. The team last year purchased a kliktronic paddle shift controller( http://www.kliktronic.co.uk/technical.htm) but never got to use it. Is it possible to control the timing of the shifts through the ecu. I was thinking of wiring from the gear up and down shift terminals at the steering wheel plug to a digital input and then using an aux output to send a signal to the control box. I don't know if this would even work but thought someone out there might be of some help.
