A/C , Idle and purge
Hi everyone ,
Want to clear up a problem with wiring on my SC 3SGE engine. Its summer , hot and my air doesnt work as it supposed to as OEM.
The 3 pins relevant are ACT , AC , FC
When the air conditioner is turned on the idle drops a bit but stalls after a sight rev.
Upon inspection 2 things noticed ACT and AC there is no connection to the MoTec, FC is connected to A33
Also with the OEM setup when the air conditioner was turned on the fans would come on buy they dont when connected to the M800 ?
Second thing found that there is nothing connected to the PRG purge valve
This is my set up
All i could find is the Temp activation control
This is the quote from the training manual
Last question as can be seen it the picture above the RSO idle valve.
Early on set up there was no connection( couldnt hold idle obviously ) but it was retro fitted
Am i correct that it should be connected to one of the AUX ?
We noticed that it was difficult to control at 250hz as per Toyota manual ? I believe its at 500 hz any reason for this and possible scenarios ?
All help much appreciated
This is my set up
