2JZ-GTE OEM Idle Air Control Valve Wiring
Postby QXZ9027MKII on Sun Jan 29, 2012 2:02 am
I'm trying to wire in the factory 2JZ-GTE IAC to the Motec M600,
OEM IAC Valve specs:
- its a stepper motor type with 4 coils,
- The IAC Valve terminal has 6 pins:
- 2pins are designated to to the battery + (B1 & B2)
- 4 pins are controlled via the ECU. and they are designated as ISC1, ISC2, ISC3 & ISC4
Mode of operation:
- as Per the factory Manual it states that if you connected the battery terminals to B1 & B2, and then connected the Negative terminal in the following order----> ISC1, ISC2, ISC3 then ISC4 The valve will open and vice verse to close the valve.
Whats the wiring method will be, do i connect Aux5 to ISC1, Aux6 to ISC2, Aux7 to ISC3, Aux8 to ISC4.
For more Info Check the Attached WD Images.
2JZ-GTE Idle Control Valve Wiring Diagram.jpg (36.41 KiB) Viewed 17570 times
2JZ-GTE Idle Control Valve.jpg (78.44 KiB) Viewed 17639 times
QXZ9027MKII
Re: 2JZ-GTE OEM Idle Air Control Valve Wiring
Postby MarkMc on Mon Jan 30, 2012 1:18 pm
Attached is a pinout based on the ISC valve from a 1UZ which should be the same as the 2JZ.
Don't use any Integral Gain, it is not necessary fro a stepper motor.
1UZ-FE stepper motor.pdf
(24.89 KiB) Downloaded 2191 times
Postby QXZ9027MKII on Tue Mar 06, 2012 7:52 am
Thanks Mark for the info gona check out and see what happens. just trying to find some time.
QXZ9027MKII
Postby The Flash on Sun Sep 02, 2012 11:57 am
i have the same question
do i have to use A31A32 A33 A34 in order to make this work?
thanks
The Flash
Postby MarkMc on Mon Sep 17, 2012 5:17 pm
Yes, Aux 5, 6, 7, and 8 are the only ones that can control a stepper motor.
