sync error
I have an input of 3.7 voltage signal from the sync sensor when the engine is not running. When it is running the voltage falls to a 0V when the tooth is passing the sensor. So there is a constant ref/sync error.
Isn't it normally the other way arround? 0v when no tooth and 3.7v when a tooth is passing.
It is a Honda cbr1000rr 2010 model. All wires are connectted like the original wiring loom. Expect Motec says that the Hallsensor needs to be connected to 8v eng and I connected it to 5v eng as per original Honda.
Any help?
Any help?
