Motec MAP sensor
Motec MAP sensor
Postby Wolf_Tm250 on Fri Oct 10, 2008 2:32 am
Hello, please help me identify which MAP sensor I bought from Motec dealer years ago, cause I'm having problem calibrating it in the M400.
The paper says:
DSEU58033
Abs 0 - 4 bar
Gauge 0 - 5 bar
Power supply from 8 to 20 VDC
Output from 0.5 to 4.5 VDC
Linear calibration from 0.5 to 4.5 VDC
But if I make a linear calibration 0.5 to 4.5 = 0 to 400 kPa, I get 78 kPa of atmospheric pressure !
If I put a calibration from 0 to 500 kPa, I get 98 kPa... that it seems to be a quite good value.
Please help me.
Wolf_Tm
Parma - Italy
Wolf_Tm250
Re: Motec MAP sensor
Postby SPowers on Mon Oct 13, 2008 12:19 pm
Sounds like the absolute and gage values are reversed. Otherwise your span and offset sounds correct. Maybe someone from Motec will confirm.
SPowers
Postby aalzuhair on Tue Oct 14, 2008 10:17 am
Edit: I looked all over the site and could not find anything that would help you ... sorry dude and the part number 58033 is used for a 500psi sensor now !!!
aalzuhair
Postby Wolf_Tm250 on Tue Oct 14, 2008 5:59 pm
No problem matesx, thanks a lot... will try to test it before using it... Bye
Wolf_Tm
Parma - Italy
Wolf_Tm250
