Boosting issue
Hey everyone, first post here.
I’m Matt, from Brisbane Australia. Currently running a Motec M400 with SLM and USB data connection.
I’ll warn you now, I’m a complete novice and just trying to isolate the issue with my car before taking it in for an updated tune.
Recently I’ve removed the catalytic converter from my car and re-did my turbo drain due to a small leak. I replaced Turbo and BOV Vac lines whilst I was in there.
Now, since doing the work I’m having issues getting boost to generate with my setup. I’m hoping someone might be able to assist me in the problem as I’m stumped on it. I also removed a portion of intercooler piping and re-plumbed. I cannot hear any boost leak nor can I see any visible issues with the vac lines.
Please find attached Diagram of my current setup.
Turbo is a TD05 Hybrid with a GT2871 centre
Boost solenoid is a Mitsubishi 2 wire 2 port setup. – Part Number
Previous workshop/tuner configured all the setup so I’m not even sure if it’s an ideal setup, however I assume it’s just a controlled bleed valve.
A few things I’ve been told thus far and I’m hoping to save time by posting these.
1. Duty cycle can be affected by removal of the cat and may be a contributing factor.
2. I’ve done something wrong. (All lines were reconnected in order and same hose lengths)
3. I’m stupid.
Based on the above information, is there any suggestions as to what I can look for on my ECU / set up?
I’ve already stripped and re-done the ENTIRE vac line setup and intercooler hoses twice now with the same result.
The only other bits of information I can supply is that the car produces 10PSI until 7.5K RPM where it begins to produce around 18 before hitting RPM cut at 8.5K. This is what has me stumped.
Also, the Boost Aim and Boost Aim Error appear to be the same, which leads me to believe that the solenoid could be dodgy, but again, I don’t know enough.
I can supply data log if required.
Thanks for your help
3. I’m stupid.
