GSXR k6 CRIP
Mon Dec 05, 2011 1:26 am
by boyler
Wondering would anyone have a stock Crip value for a Suzuki GSXR k6 engine. I'm using a m400 ECU. It has a ref trigger wheel of 24-2, had the ECU set up on a k3 before and was hoping to plug that map straight into my k6 but the k3 had a ref trigger wheel of 8 evenly spaced teeth.
Re: GSXR k6 CRIP
Mon Dec 05, 2011 5:56 am
by insomnia
105° or 465°you need to check where is the cylinder 1 wired.
and you have 8 injectors, what's happend with the M400 in this case???
Re: GSXR k6 CRIP
Mon Dec 05, 2011 10:48 pm
by boyler
No there is four injectors on the engine. These are wired up in the firing order 1243.
Re: GSXR k6 CRIP
Tue Dec 06, 2011 3:51 am
by insomnia
From the factory the GSX-R600 K6, 750 K6 and 1000 K6 use 8 injectors...
