GSXR k6 CRIP
GSXR k6 CRIP
Postby boyler on Mon Dec 05, 2011 1:26 am
Wondering would anyone have a stock Crip value for a Suzuki GSXR k6 engine. I'm using a m400 ECU. It has a ref trigger wheel of 24-2, had the ECU set up on a k3 before and was hoping to plug that map straight into my k6 but the k3 had a ref trigger wheel of 8 evenly spaced teeth.
boyler
Re: GSXR k6 CRIP
Postby insomnia on Mon Dec 05, 2011 5:56 am
105° or 465°you need to check where is the cylinder 1 wired.
and you have 8 injectors, what's happend with the M400 in this case???
insomnia
Re: GSXR k6 CRIP
Postby boyler on Mon Dec 05, 2011 10:48 pm
No there is four injectors on the engine. These are wired up in the firing order 1243.
boyler
Re: GSXR k6 CRIP
Postby insomnia on Tue Dec 06, 2011 3:51 am
From the factory the GSX-R600 K6, 750 K6 and 1000 K6 use 8 injectors...
insomnia
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 9 guests
