Problem with TPS
Hello.
I'd like to have your advices with a TPS I'm currently using on my car, Toyta STD-non linear.
After calibrating fully closed and fully open position, I just saw that at fully open I get 96%, but as I decrease a bit on the pedal, I get 100%.
So I had a look on Raw Input Voltages, and I saw that I get 0.980 V. at fully open throttle, but I get higher voltages ( around 1.050 v. ) as the throttle is a bit back from the fully open.
What should I do to fix it ?
Thank you.
Thank you.
