connecting M800 via Can or serial to Racetechnology loggers
Good day
we have found ourselves in the compromised situation of using racetechnology logger and dash display and a m800 ecu.i have a DL2 and dash 2 connected via the racetechnology serial adapter and I also have the CAN adapter. either way i don't have any communication from the motec to the race technlogy.
according to race tech (RT) i should set the motec to 19.2kbaud, data set 3 using the crc232 set ups (the same i believe that is used for telemtery)
but no luck in comms like this
i have also tried using a CAN adapter but also no luck there.
as the RT requires single message say 1 temperature alone to be decoded at a time, while motec send a bundle of data in 1 message.
Does anyone have any advice for me please? how can i check whether the motec is even sending serial data out. i know it is sending CAN as it connects with the HTC adapter.
Thank you kindly
Greg Bailey
Thank you kindly
Greg Bailey
