m400 run high & low impedance injectors simultaneously?
Fri Oct 14, 2011 4:46 am
by edickma1
Is it possibility for for an M400 to run both saturated and peak & hold injectors at the same time? there are only 4 injectors being considered for implementation, 2 low flow saturated injectors for low loads and 2 higher flow peak and hold injectors for higher loads, is this a possibility?
thanks guys
Re: m400 run high & low impedance injectors simultaneously?
Mon Oct 17, 2011 4:23 pm
by MarkMc
If you run the staged injection you can specify different output control for the two different sets of injectors. I assume it is a two rotor or 2 cylinder engine?
Tue Oct 18, 2011 1:24 pm
by edickma1
thank you very much for your response, this is a 2 cylinder aprillia engine
Fri Oct 21, 2011 4:33 pm
by MarkMc
Ok, no problem then.
