m400 run high & low impedance injectors simultaneously?
Postby edickma1 on Fri Oct 14, 2011 4:46 am
Is it possibility for for an M400 to run both saturated and peak & hold injectors at the same time? there are only 4 injectors being considered for implementation, 2 low flow saturated injectors for low loads and 2 higher flow peak and hold injectors for higher loads, is this a possibility?
thanks guys
edickma1
Re: m400 run high & low impedance injectors simultaneously?
Postby MarkMc on Mon Oct 17, 2011 4:23 pm
If you run the staged injection you can specify different output control for the two different sets of injectors. I assume it is a two rotor or 2 cylinder engine?
Postby edickma1 on Tue Oct 18, 2011 1:24 pm
thank you very much for your response, this is a 2 cylinder aprillia engine
edickma1
Postby MarkMc on Fri Oct 21, 2011 4:33 pm
Ok, no problem then.
Users browsing this forum: No registered users and 65 guests
