Ref/Sync Input Impedence
I am planning to run M800 with the stock ECU.
The stock ECU is running a 60-2 reluctor signal for REF and single pulse hall for SYNC.
What is the proper way to tap the REF and SYNC signal into M800.
Should I just tap the REF onto the +ve and leave the -ve alone to stock ECU
OR
Should I tap the REF onto the +ve and tap the 0V to -ve?
Is the REF input impedance high enough as not to distort the original signal?
We want to maintain the original signal so the ECU can see proper RPM.
TQ
OR
TQ
