Mazi wrote:I can't find the way how to cut off ignition for infinite time via switch on digital or AT input.
MarkMc wrote:What do you actually want to do?
Mazi wrote:MarkMc wrote:What do you actually want to do?
At least two things.
Second one is ignition cut caused by belt failure on external oil pump dry sump engine. I have a small electronic device capable to measure speed of oil pump and send it over CAN bus. An ignition cut table with RPM on X and Oil Pump RPM on Y will be fine.
First one is gearshift cut controlled by another source.
http://www.geartronics.co.uk/closedloop.htm
