Data down the CAN when an ecu has no logging enabled?
Will a *00 series ecu send data for external logging down the CAN BUS even if the ecu in question has no logging enabled? I'd try it for myself, but my M800 ecu does have logging enabled. I am buying an M600 for another project and it has no logging enabled, I am wondering if it will still output selected data channels via a Custom CAN set up for logging by an external logger? Thanks.
As an aside, my M800 has GPS on the serial input, and I have enabled Custom CAN to send GPS Speed, Lat and Lon, GPS Time, Sats Used and Sat Quality, (as well as a host of other stuff). My logger sees Lat and Lon, does the maths and gives GPS coordinates, it also sees GPS Time correctly. It sees nothing at all for GPS Quality and Sats Used. All other data channels are read correctly and reliably. Is there anything "funny" about the data for these two channels down the CAN BUS?
