Fuel second load map, offset or percentage
Postby Mr ganbatte on Thu Sep 15, 2011 2:13 pm
Could some one please tell me what offset mode means on the Fuel secondary load map.
Mine is set up as no. 1 throttle based offset mode
Percentage is % of IJPU. Offset is ??
My set up is a multiple throttle body RB26 .
Which is best, percentage or offset.
Any plain explanation of the latter would be much appreciated.
Cheers
Mr ganbatte
Re: Fuel second load map, offset or percentage
Postby MarkMc on Thu Sep 15, 2011 5:56 pm
An offset is a straight addition of Fuel, i.e. if your main table says 40% of IJPU and your Second load table is 50% then the total fuel will be 40% + 50% = 90%.
A percentage is a multiplier....so in the first example we have a main table of 40% and asecond load table of 50%, the math's now is 40% + (40% x 0.5) = 60%.
Most people do it by percentage, i.e. if the second load table is 50% you are adding 50% more fuel to what you have from the main table.
Postby Mr ganbatte on Thu Sep 15, 2011 7:30 pm
MarkMc wrote:An offset is a straight addition of Fuel, i.e. if your main table says 40% of IJPU and your Second load table is 50% then the total fuel will be 40% + 50% = 90%.
Fantastic thank you very much.
Mr ganbatte
