Speed and Distance
Hi guys,
With a M800 on my bike i use a gear sensor and a speed sensor on the gearbox output. Works fine.
Now the two questions:
1) in I2 Std i see gear and speed, but when i hit F9 nothing happends. How can i switch between speed
and distance or what's the right way to see both channel ?
2) because i use the OEM speed sensor on the gearbox output, what can i do to have correct speed
if i forget to change the parameters after changing final ratio? (ie after 2 different practice session, i cannot
compare the speed if i change the final ratio...)
Thank for your advice.
Francois
Francois
