Supercharger boost control with DBW throttle
Hello
I do have a Lotus Elise with a Honda K20Z4 engine and Rotrex supercharger. I’m currently using an air restrictor (~38mm) mounted at the superchargers inlet to keep the boost at ~0,6bar –> 280bhp
During next winter I want to do some changes to the engine and run much higher boost without an air restrictor -> but I’d like to keep the boost down in the lower gears… I know it would be possible to do this by using an blow off or bypass valve, but shouldn’t it also be possible using the DBW throttle??? (especially if it’s mounted before the supercharger???)
Thanks for helping
-Martin
Thanks for helping
-Martin
