REF/SYNC errors, M800, Subaru STI
Postby isox on Fri Jul 29, 2011 3:02 pm
Hello again, MoTeC guru.
Please, help me again.
Now with REF/SYNC errors.
I'm very afraid of tuning them without your advice.
For now, after 3-5min run I've got these errors:
Sync Lo Level
Ref Noise Ar
Ref Runt
As I understood from manuals, for "Sync Lo Level" error I must calibrate "Ref Trigger Voltage". Is it ?
For "Ref Noise Ar" it's problems with REF filter table. Yeap ? ))
And what to do with Ref Runt ?
Please, give me direction to calibrate these values.
isox
Re: REF/SYNC errors, M800, Subaru STI
Postby isox on Fri Jul 29, 2011 3:16 pm
Oh, forgot about main problem.
Thats errors appears on running engine, after cranking.
After them, engine on 1000rpm goes in "diesel mode " =)
Some low-freq vibration appears.
When there is no errors, no vibrations on idle detected.
isox
Postby isox on Sun Jul 31, 2011 9:17 pm
By the way, I'm wasted two days for correcting problems.
REF/SYNC problem solution was:
- decrease voltage in specific RPM
- correct filtration on the same RPM (my tuner set 124 (max) for 1000rpm, I decreased it to 82)
So, there is no more problems with ref/sync. Sometimes "runt" appears, but, as I understood from forum, that does not matter any big problems.
With "diesel mode" I corrected Fuel trim in MAP compensation. For idle pressure (30kPa) I set -45 trim agains -60 (my tuners specification).
isox
Postby SpeedTechniques on Sat Oct 15, 2011 6:30 am
I have a fair amount of experience with an M800 on a Subaru STI. Shoot me an email I might be able to help.
jared@speedtechniques.net
SpeedTechniques
