Tuning for Fuel Accel Enrichment
Hey guys,
I finally got my car tuned at the dyno and all the fuel map and ignition map are done. The tuner tuned for the fuel enrichment as well but I thought it can be done better.
I plan to log the data and do some street tuning myself on the accel fuel enrichment setting and would like to have some tips before I starts.
Beside any suggestions from any of you, here are some of my questions. Base on the current setting and logging data, I get a spike up(lean) in A/F(lambda) the moment I accelerate, then the curve comes down showing rich.
1) Assume a properly tuned accel enrichment should give a flat curve on A/F(lambda)? meaning regardless the rate of acceleration, the lambda should not have drastic spike up and down?
2) Base on the logging data above, is that mean I should up the accel fuel sensitivity at the same time up the accel fuel decay? The more sensitive setting should take care of the lean part of the accel and the high accel fuel decay should take care of the rich part of the lambda?
My understanding on accel enrichment as below..
Accel Fuel Clamp : The maximum % fuel enrichment for acceleration
Accel Fuel Decay : How quickly the computer will remove this enrichment
Accel Fuel Sensitivity : How frequent should the computer recalculate the fuel enrichment due to whatever the x-axis(rpm, TP%)
Please correct me if I'm wrong.
Cheers
Andy
Cheers
Andy
