Firmware downgrade
Hi
I recently had my car tuned on firmware 3.52J and after about 6 months I upgraded the firmware to 3.52P
Now the plugs carbon up really easy and it cannot hold a steady idle.
Misfires heaps when backing off after high speed on the track.
Everything else has not changed.
To revert to the old firmware is it just a matter of plugging in to the ECU with ECU manager v 3.52J installed on the laptop rather than the newer version V3.52P? Then it should downgrade the firmware?
I have a backed up copy of the original config file when it was tuned so if it downgrades I will load that file also and see how it runs then.
I am working away and was just after some advice for when I get home.
Cheers
Cheers
