sphilips wrote:Arve Flaat wrote:Hi
I have checked with AIM about the CAN. Their CAN is only Receive, not transmit.
You have too wire the GPS too the M800 and send the info too the MXL, or use a SDL3.
AF
How can I connect the gps from the mxl to both the m800 and mxl?
If the AIM receives and the m800 receives, then you put the GPS onto CAN via an STC, and the make sure the m800 and the AIM both are looking at the CAN right address for the GPS.
You probably need to find out from AIM what address they need to look at, or how to change it...
Same for the M800.
If they both receive then they can both be on the same CAN receiving.
