Testing Nissan Ignition Module
I am trying to run a Nissan 22020 50F01 s13 Ignition Module on our M400 running a gsxr600.
Its wired up as:
power to coils
coils to one side of ignition module
then signal to ecu and ground from the other side of ignition module.
I tested the outputs last week and all plugs fired, now today there is nothing. Power is getting to coils. Is there a way to test the module unit on its own? Or could some of my settings in the ignition setup have damaged the ignition module? The only tests done was the 'test outputs' and all worked and then we tried to fire up today and nothing so I dont think it was turning long enough to burn something out
Heres my settings on the m400
Any ideas?
Its wired up as:
power to coils
Any ideas?
