Bizarre data logs from my M800
Postby Chris Wilson on Sun May 15, 2011 9:24 pm
Engine is twin turbo RB26DETT Nissan in a RWD Skyline track car, and at the venue these logs came from appeared to be running fine, as normal. But when I reviewed the logs at home later the inlet air temps show up to over 800 degrees, which is obviously wrong (I hope.... ;)), and T/Pot openings of 800% plus. Other logged data is also odd, like massive ECU battery volts, et cetera. Something is awry, but never having seen a log like this I don't know what, can someone take a look and advise please? Thanks. http://www.chriswilson.tv/funny.zip and I used Interpreter I2 Standard to view it.
Chris Wilson
Re: Bizarre data logs from my M800
Postby Sean on Mon May 16, 2011 12:35 pm
Wow :o :shock: Bad earth, alternator/regulator failing?
Sean
Postby Chris Wilson on Mon May 16, 2011 6:30 pm
I also sent the datalogs to Dave Rowe, a Motec trained independent here in the UK, and he replied it was due to me having more than one map in the M800, and differing data log set ups for the two maps. I am not quite sure what he means, to be honest, although this started after I altered some parameters of one of the maps. If he is here in the UK, and not working away I will try and contact him for clarification, but maybe this will ring s bell for someone here? Thanks.
Chris Wilson
Postby JamieA on Tue May 17, 2011 5:52 pm
I havent looked at this in detail, nor have I tested this, but assuming that it is possible to be set up that way, Dave Rowe wouldbe correct that different log setups would cause a problem. heres how.
you have a log setup with this in map 1, then log some data
TPS
RPM
Speed
ET
AT
OT
if you swap to map 2 without a download, to this.
TPS
RPM
Speed
ET
OT
AT
When you download, the logging from map 1 would have AT and OT around the wrong way.
Normally you would be blocked from doing this by being forced to clear the logging during this change of settings, but this cannot be done in an on the fly map swap.
Set your logging settings to be the same in all swapable maps to avoid this issue.
-Jamie
JamieA
Postby Chris Wilson on Tue May 17, 2011 6:34 pm
Thanks Jamie, I set both logging set ups the same for both maps and the issue appears resolved. Is this considered a bug or a feature? ;)
Chris Wilson
Users browsing this forum: Google [Bot] and 6 guests
