V8 staged injection
Fri May 13, 2011 2:45 am
by prostang
M800 16 injectors is there any way to stage them
Thanks Steve
Re: V8 staged injection
Thu May 26, 2011 4:19 pm
by MarkMc
No sequentially, you would need 16 outputs to do this and the M800 only has up to 12.
If you wanted to stage the injectors in two sets you could do it as a semi sequential engine......basically run it as a four cylinder two stroke with waste spark.
What is the engine used for? Are you wanting to change the position of the injection (N/A) or just get more fuel (i.e. turbo)
