V8 staged injection
V8 staged injection
Postby prostang on Fri May 13, 2011 2:45 am
M800 16 injectors is there any way to stage them
Thanks Steve
prostang
Re: V8 staged injection
Postby MarkMc on Thu May 26, 2011 4:19 pm
No sequentially, you would need 16 outputs to do this and the M800 only has up to 12.
If you wanted to stage the injectors in two sets you could do it as a semi sequential engine......basically run it as a four cylinder two stroke with waste spark.
What is the engine used for? Are you wanting to change the position of the injection (N/A) or just get more fuel (i.e. turbo)
