Motec and autometer tacho's
Hi guys,
I know it's probably been covered a heap of times but I can't find the exact answer that suits my application in regards to hooking up an autometer tacho with Motec ECU.
I have an RB30ET in an LC Torana and a motec ECU. I currently have a tacho hooked up to it and it works but reads very incorrect. I have snipped the wires so it's calibrated to a 6 cylinder.
I believe I have a coil negative type of gauge. I've read other threads that suggest using a resistor to fix this but the other threads had no tacho reading at all, I do, it goes well over 10,000rpm though so i know it's way out.
Will a resistor fix this? What resistor do I get? What else could it be?
